Show Most Recent Data Point w/ Dynamic Text Widget
910
07-01-2024 12:17 PM
MFazio
Is it possible to show the most recent data point using the dynamic text widget?
TIA!
Ke_Xu
by Esri Regular Contributor
Hi MFazio,
Text Widget doesn't support this now. Once we have the solution, I will let you know.
Thank you.
ShengdiZhang
Hi @MFazio ,
The text widget supports Arcade expression in the June 2025 AGOL release.
You can use a similar script as the following:
var fs = $dataSources["dataSource_id"].layer;
var sorted = OrderBy(fs, "date_field DESC");
var fpt = First(sorted);
return fpt.date_field;
Shengdi
