Shadowcast analysis does not clear
7010
10
11-01-2023 09:31 AM
JoCondliffe
I'm using the 3D toolbox in Experience Builder, the shadowcast analysis does not clear when 'Clear Analysis' is clicked. The shadows then stay permanently on the screen. Is this a bug? It didn't use to do this.
Same / similar problem as in this Instant app issue https://community.esri.com/t5/arcgis-instant-apps-ideas/shadowcast-widget-error-in-3d-viewer/idi-p/1...
Wei_Ying
@SveinungBertnesRåheim Some updates:
1. Date selector problem: this issue only happens when the widget is in a widget controller, which configured to open multiple widget. We will fix it in next release.
But a workaround is to use the single widget open mode in widget controller or not to use 3D toolbox in widget controller.
2. Open shadow case again after clear analysis, does not render: this issue is a known limitation. We decide to fix it in next release. The workaround is to zoom in/ zoom out/ move around the map, the shadow will show.
