Set max/min zoom levels for Experience Builder Developer Edition
4844
7
07-26-2023 10:03 AM
Brian_McLeer
MVP Regular Contributor
Has anyone had any success with limiting how far out or in you can zoom on a map in Experience Builder? I know I can set the zoom levels in Pro for the map service, but checking on a way at the application level within Experience Builder.
Ke_Xu
by Esri Regular Contributor
Hi All,
This feature has been released on ArcGIS Online in February 2025 and will be released on Experience Builder Developer Edition 1.17.
The map bar or bars show the level of detail(LODs) of the basemaps in the connected maps.
Ke
TonghuiMing
Hi @Brian_McLeer
There are a few similar inquiries:
https://community.esri.com/t5/arcgis-experience-builder-questions/zoom-and-pan-limit/m-p/1213848#M53...
ENH-000148335
We are evaluating this feature as a possible enhancement.
AlainBEAUREGARD
Definitely a must, especially considering it is available in Web App Builder...
AngelaSchirck
Please do!
MayaFleagle
Hello,
Is there any update on this? I want to use this feature in a project. Also, I have another question about the Experience Builder. Is there a way to override the set zoom increments for the map widget? I have found that the default zoom increments zoom in or out too far. I would like to find an in-between.
Thank you,
Maya
AndreasHall
The zoom increments are set when the basemap is created. You can create your own basemap using the zoom increments that you want.
Ke_Xu
Hi All,
Ke
Brian_McLeer
Thank you, @Ke_Xu for the update and implementing this idea.
