Set Default Surgery Type in List Widget
913
08-26-2024 11:03 AM
Labels (2)
MadhavJani
I’m working on a map that displays different types of surgeries, each represented by a circular area around a location based on the number of days. On initial load, the map is cluttered with circles from all the surgery types, making it less user-friendly.
The surgery types are filtered using a List widget, and I would like to set one of the surgery types as the default selection in the List widget when the map loads. This way, only the circles related to that specific surgery type will be visible initially, and users can choose other surgery types as needed.
Has anyone implemented a similar solution or have any suggestions on how to set a default filter in the List widget to reduce the clutter on initial load?
Thanks in advance for your help!
