Selection tool selects features from hidden layers when visible range is define
1050
07-14-2024 04:16 PM
Dvirus
When using a selection tool, the tool selects features from layers that are not visible due to visibility range (defined in web map)
It's a bug?
How can I select only from visible features on map?
Affected version:
EXB 1.12 - Portal/Developers edition
EXB 1.14 Developers Edition
Ke_Xu
by Esri Regular Contributor
Hi Dvirus, please use Select widget. Toggle off the layer that you don't want to use.
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/select-widget.htm
