Selected features from data source in Experience Builder
459
01-08-2026 09:59 AM
ferdpura
We are licensed for version 10.9.1 of ArcGIS enterprise. We are creating a notification process based in buffer inputted by user  in Experience Builder based on the following documentation
https://geospatialtraining.com/how-to-configure-the-query-widget-with-a-spatial-buffer-in-experience...
Our issue is that the “Filter by selected feature from data source” option is not available in Experience Builder within our ArcGIS Enterprise portal. We followed the recommended settings when configuring the web map and publishing the web layer, but the option still does not appear.
However, when using Experience Builder in ArcGIS Online, the “Filter by selected feature from data source” option is available for the same published web layer.
Is this because of the version used?
Ke_Xu
by Esri Regular Contributor
Hi @ferdpura,
Yes, it was released on Enterprise 11.0. You can use the ArcGIS Experience Builder Developer Edition 1.6 or higher version with Enterprise 10.9.1.
Ke
