Select Widget zooms to entire world when adding to selection
596
09-11-2024 07:09 AM
KG_427
Using ArcGIS Online - I have an application built allowing the user to select parcels either manually or from a buffer around road projects.  However, when attempting to add to selection, the web application zooms out to show the entire world after selecting additional features. I have attached a video of this. If you try to "zoom to" from the selection widget, it does not zoom back to the selected data, it stays at the world extent. The data extent seems normal when viewing in a web map or ArcGIS Pro, this behavior only occurs when adding features to a selection.
How can this be resolved? It's making it rather unusable to our end users who will have to be constantly scrolling back in to select or deselect a few parcels.
Ke_Xu
by Esri Regular Contributor
Hi Kim_Graham,
Thanks for bringing up this. Could you share the app for us to troubleshoot this issue further?
Ke
Ke_Xu
Hi @KG_427,
Could you create a support ticket with ESRI support for this?
Ke
KG_427
Hi Ke, my apologies, I guess I missed your first response. I have actually taken the app down for now due to staffing changes. But, yes, I can open a ticket with support to have them look at.
Kim
