Select Widget by folio, change selection to fill polygon to make it more visible
927
06-15-2023 10:25 AM
SanchezNuñez
Hello everyone,
Is there a way on the Select Widget, when I do a search by folio, to change the selection to fill the Parcel polygon to make it more visible.  Currently it only draws a line around the parcel polygon.
IssyAmis
Hi there @SanchezNuñez ,
To change how your polygons are selected in Experience builder, you should be able to use the "feature selection colours" option that appears in the "content" tab when editing your map widget.
If this doesn't answer your question, could you please explain further what your workflow is and what you are trying to achieve.
Many thanks,
Issy
