Select Data Widget Repetitive Data Actions
96
a week ago
JaredPilbeam2
I want an export on the Select tool. Why are there two? If I go into the Data action tab of the Select tool and disable the data action they both go away. How do you get just one?
DanielFox1
Hi @JaredPilbeam2
The first export option is driven by the widget and the second from the feature layer
To remove the option from the widget:
1. Select the widget
2. Select Action
3. Turn off "Enable Data Action"
This will turn off all the other features in that list
JaredPilbeam2
Hi @DanielFox1
That's what you'd think. Like I said originally, when I go into the select tool pane and disable the data action they both go away.
