[Select and Add Data Widgets] Inconsistencies with symbology appearing when adding to map.
167
07-08-2024 01:33 PM
StevenSGIS
Hello,
I'm creating a web application through EB and I've noticed an inconsistency with either (or both) the:
  • Select widget
  • Add Data widget
The process:
  1. I've been selecting polygons from a layer that is hosted as a feature service and exporting my selections as my own item in AGOL.
    1. When I go to view the item - everything looks fine through AGOL Map Viewer - the polygons have been successfully exported with the symbology preserved.
  2. Now I go to the Add Data widget and add the newly created item.
  3. This is where inconsistencies begin.
    1. After adding the data and after selecting "add to map," the symbology becomes entirely empty.
However, I would like to note that it at steps 2 and 3, sometimes the item will be added to the map successfully with the symbology preserved, and other times not.
I've just recently tested it again by:
  1. Repeating steps 1-3 as a separate item.
And now, for whatever reason, the symbology shows up appropriately.
Is this a bug? What exactly is happening here...
