Search Widget, when I click the X (Clear) it Zooms back to the whole map
1143
09-07-2023 05:33 AM
SanchezNuñez
Hello everyone,
When I search for an address with the search widget, and select the address in the Results panel, it zooms to this address. But when I click on the X to Clear the Search button, it zooms back to the initial extent.
How can I fix that?
JoseSanchez
Found a solution. in the Actions tab I only added the following triggers:
 - Records created:  Show On Map
 - Record Selection Changes: Map Zoom To.
Adding trigger Records created:Map Zoom To.   Produces this behavior.
JoseSanchez
