The "show on map" location highlighting does not work for me in the search widget. My search source is a feature service from that is in my map widget. I added an action to the search widget, Records created > Map > Show on map > with custom symbols and I have checked "Set as operational layers". The search widget does produce a list of matching records, but the map widget never highlights the locations of any of the records . I would expect this to behave in a similar way to the search widget from App Builder when there are multiple results. We are on Enterprise 11.5. I have tested with the same feature service that I used for search in App Builder and with a few other feature services. My feature services are hosted on our ArcGIS Server.
Hi Timothy,
The Records created trigger is only compatible with Locator search sources. Please see the following documentation:
You can still zoom to a search result by using the Record selection changes trigger, setting the map as the target, and zoom to as the action.
I hope this helps!
