Search widget actions not working
561
04-22-2026 09:43 AM
CITZCONNDataTeam
Since yesterday, the search widget is not working properly. I have set the Actions 'zoom to', 'pan to', and 'show on map' for each record created. However, after find the record in the search bar, the feature is highlighted but the map don't move. It was working fine two days ago. Any thoughts how can I solve this?
JeffreyThompson2
MVP Frequent Contributor
Try a Record Selection Changes Action.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
Try removing Pan To. It's redundant to have both Pan To and Zoom To and they can interfere with each other.
GIS Developer
Ke_Xu
by Esri Regular Contributor
Hi @CITZCONNDataTeam,
Add both Pan To and Zoom To, with Zoom To having higher priority. Have you tried using a different browser? Does the issue occur on other computers as well?
Ke
CITZCONNDataTeam
Nothing worked. I removed all triggers and tested one by one and it seems the triggers are not working for 'records created'.
JeffreyThompson2
GIS Developer
CITZCONNDataTeam
Thank you Jeffrey, it worked well!
