I ask myself exactly the same question and the answer is not as simple as it might seem 😐
The startup of ArcGIS Web AppBuilder is with Node.js But in server configuration (load server.json)
OFF
SETLOCAL EnableDelayedExpansion
TITLE Web AppBuilder for ArcGIS
SET serverPath=server
SET serverjsFile=server.js
SET port=3344
SET wabVirtualPath=webappbuilder
SET portTaken=0
IF DEFINED USERDNSDOMAIN (SET FQDN=%COMPUTERNAME%.%USERDNSDOMAIN%) ELSE (SET FQDN=%COMPUTERNAME%)
IF DEFINED PROGRAMFILES(X86) (SET nodeFile=node_x64.exe) ELSE (SET nodeFile=node_x86.exe)
To start EXB, we launch an application running under Node.js and autocall package.json where is the .bat file
npm start
I am not a Node.js specialist 😊
Thank you for any inputs,
Benjamin
