Revert to published version of Experience Builder (cancel changes)
8982
11
05-09-2022 10:24 AM
JulieMikolajczyk
We were modifying a published Experience Builder application and we are now receiving an error "404: Resource does not exist or is inaccessible."
The published version works fine. While it would be nice to know what caused the error, the immediate need we have is to revert back to the published version and discard all unpublished changes. How can we accomplish this?
rmcooper_wcpss
Thanks for this tip. It really helped me out after we implemented a change to our Portal URL.
I am curious: where on the Portal server is the config/config.json file?
I would have thought it was in the actual directory for the item in the contents directory: portal/usr/arcgisportal/content/items/{{item ID}}/resources/config/config.json
However, I believe this is only the config for the published version. I've looked high and low and cannot find where config.json used by the builder application lives. I'm glad the ArcGIS Assistant exists and can be used to access this file though!
ahargreaves_FW
 THANK YOU!
