Required field error in Survey123 cause it to reload when clicking on map in Experience Builder
739
03-21-2023 09:46 AM
AJM
I have a web map in experience builder that sends data to a survey123 survey when a point feature in the web map is clicked. This works fine. However if the survey is attempted to be submitted and errors are detected for missing required fields, and the user then clicks back on any feature in the map the survey reloads and looses all the data that was entered.
Is this a bug or is there a setting I need to change?
