Remove 'Powered by Esri' from map widget in ExB
1809
09-01-2020 01:29 AM
KamranYusaf1
I am working with the ExB(dev edition offline) and i need to remove the 'Powered by Esri' logo in the bottom of the map widget. Where can i do this?
The application will only be used internally in our company, and we don't use any Esri services or maps.
DavidMartinez
Hello,
The Powered by Esri attribution is required since it using the JS API.
David
danieloccasionally
What about moving it below widgets?
