Related table doesn't appear in Experience Builder after June 2024 update?
2258
06-28-2024 04:09 PM
KeithSalmon
After the June 2024 Update, a map which was working ok now won't display the Related Table in the Experience Builder page which uses it.
The map and form still work ok in the Field Maps App - just not in Experience Builder.
I have cloned a new page and reconfigured the map, but the related table still won't appear in the Exp Builder page.
Suggestions for solving welcomed.
The details are documented here: 240629 Related table won't appear in Experience Builder after June 2024 Update
Jianxia
@KeithSalmon, thanks for the details. Could you please contact Esri Support?
KeithSalmon
Hi Jianxia
Thanks for your reply - I got a reply from support<[email protected]saying "You are receiving this email because we are unable to respond to new inquiries sent directly to [email protected] or [email protected] visit the Support website for options to contact Technical Support. For non-Technical Support related issues, please contact your Distributor or visit the Contact Us page."
I have now submitted it as a bug (https://support.esri.com/en-us/contact/report-bug/thank-you?subID=zNih-Sa9dH-LrvQxcdDDI)
I have also emailed Eagle Technology in NZ.
Regards Keith
AndrewWilson34
Hi @KeithSalmon,
There is an option under the General settings in the Edit Widget that will enable you to edit Related Records that are in the Form.
Hopefully that helps.
Cheers
Andrew
Laura
by MVP Regular Contributor
I submitted a bug as sometimes I could see related records with that toggled on however that is how you are supposed to get to show them in exb, yes.
