Related Table Data in Widgets
370
09-30-2019 04:21 PM
RogerCleaves1
New Contributor III
Can we please get related table data available in the text widgets?  I'd like to be able to show in the details pane the information associated to that feature from the 1-many related table.  I could see this use case being very beneficial!  I've tried using a work-around by building an arcade expression on the layer's popup to pull the information through via FeatureSetBy, but that custom expression isn't available in the map or widgets either!
Thanks!
XanderBakker
Esri Esteemed Contributor
Hi roger.cleaves_DTSC ,
Can you post this as an idea? ArcGIS Ideas  I would definitely +1 it.
