Related Table and Chart in Experience builder
1895
02-13-2024 08:49 PM
Labels (2)
OliviaFisherWilliams
I want to use a related table to update a chart (both have the same date) that is related to the map (different data same common attributes). They all have the same common attributes (ie Site Location). I have been trying triggers unsuccessfully. I am want the sites on the map to be the only sites in the table then use the table to update the chart. How do I do that?
Tags (3)
ShengdiZhang
Hi @OliviaFisherWilliams ,
I think you can add the message action Record selection changes - Framework - Filter data records to the table widget. For the Action data, you can select the related data used by the chart widget. Then, once a feature is selected from the table widget, the chart will display the corresponding information for the related data.
Regards,
Shengdi
