In ExB v. 1.10 the supported version of React is 17.0.2.
As a developer for custom widgets in ExB, would like to use some of the npm packages in my application. However, some of them require React 18.x
So, here is my question. Can we upgrade React to 18.x, and if so, how can we perform the upgrade without affecting the functionality of ExB?
As a side note, I think it would be very useful to include on the table for ExB versions, a column with the version of React supported.
https://developers.arcgis.com/experience-builder/guide/release-versions/
@Jianxia ?
Thank you.
Thanks. As this is our first time to hear the request to list the React version in the table, we’d like to collect more information about it.
@LefterisKoumis , we plan to upgrade the version of React to 18 in the upcoming developer edition in March. Currently you can't upgrade it by yourself. As for listing the version of React in the documentation, could you help elaborate it a bit? Thank you.
Thank you for your response. For the listing of the React versions, I was suggesting to change the table format shown on this page by adding the last column.
to this:
Thank you.
Developing custom widgets in ExB requires React and developers need to be aware which version of React can each version of ExB can support. So, adding the additional info in the
will be very helpful.
