"null" header in Edit Widget in Experience Builder
1199
07-19-2023 01:58 PM
Labels (2)
wrumley_asheville
I'm trying to configure the Edit Widget in Experience Builder and I'm running into a "null" header in the widget whenever a feature is selected. I've configured text for the title, subtitle, and description text as well as the header of the form builder in the web map that this is drawing from . The Edit Widget is set to use web map settings for the edit form. Does anyone know what this "null" (highlighted) is drawing from? In other EB apps I've made, it simply says "Edit feature."
KatieHansen_NIFCAdmin
Hello,
I don't know if you are still waiting for a response from someone but I had basically the same question and received this answer:
Re: Experience Builder edit widget header not edit... - Esri Community
