"Deploy to Web Server" for ArcGIS Enterprise
1681
02-07-2024 01:40 AM
Labels (2)
AravinthkumarBalasubramanian
Hello All, I have installed Experience builder developer edition V 1.11 both Server and Client install. I have ArcGIS Enterprise with Admin rights, I have create an application in the portal and used the "App id " and the portal URL to sign in using the https://localhost:3001/.
I have created a WebApp and published in the localhost, I have downloaded the App and unzipped and opend the config.json file and in the client id - I have used the App ID.
I am using this method https://developers.arcgis.com/web-appbuilder/guide/xt-deploy-app.htm
But I have lost in the step 2, How do I deploy to the Webserver, a detailed steps will be very helpful.
I have pasted the Unzipped App folder in the server folder of Installed Experience builder. How do I deploy the Webapp into my ArcGIS Enterprise portal ? Any insights will be very helpful. Thank you.
JasonBOCQUET
Hello @AravinthkumarBalasubramanian i don't understand, do you want to deploy an Experience Builder application or a WebApp Builder Application ?
If it's a Experience builder, you have to follow this : https://developers.arcgis.com/experience-builder/guide/deployment-topics/
do not forget this : on your application in your content > parameter > scroll down to "application" section and add https://portaladress.com/<folder_name>/ (the unzipedd app folder) to the URL "data source" and in the URI direction by clicking to update next to the register section.
JasonBOCQUET
