Publishing a Web App directly from ArcGIS Experience Builder Developer into ArcGIS Enterprise Portal
3405
02-12-2024 04:54 AM
AravinthkumarBalasubramanian
Hello All, I have an ArcGIS Enterprise Portal and I wanted to create WebApps and Custom widgets and publish into the Portal.
So I have Installed the Experience builder V 1.11 on my local and Used my portal URL and App ID in the https://localhost:3001/ to create a webapp and published the App. But I cannot see the WebApp in my Enterprise portal.
Is it possible to publish the App directly from the Experience builder developer edition to the ArcGIS Enterprsie portal? I cannot find any solution so far. Any Inputs will be very helpful. Thank you.
2 Solutions
JasonBOCQUET
JasonBOCQUET
Here you are on the "Experience Builder" question section; your problem seems to be relative to the "Web AppBuilder" question section (link : https://community.esri.com/t5/arcgis-web-appbuilder-questions/bd-p/arcgis-web-appbuilder-questions)
And for the web server, you have to find the wwwroot folder on your network.
JasonBOCQUET
Hi @AravinthkumarBalasubramanian  : to deploy an experience builder on your Portal, follow this : https://developers.arcgis.com/experience-builder/guide/deployment-topics/
Hi @JasonBOCQUET
Thank you for your input.
I tried to follow this instruction from you  Deploy your app—ArcGIS Web AppBuilder | ArcGIS Developers
But I am already lost in the step 1, what exactly a web server here. I am using ArcGIS Server. But I don't understand where to copy the app folder.
Is there any way to directly publish the app into the Enterprise like In an Instant app builder ? Or solution for this deployment using the web server also be very helpful. Thank you.
JasonBOCQUET
Thank you.
