Problems making edits in Experience builder
388
a week ago
NickPotter
After a recent Esri update I'm having problems updating my webapp in experience builder. I'm using the edit tool but rather than just updating one or two things in the layer and leaving everything else blank its asking for a value in everything. it was working fine before.
LakesGISMaps
I am having the same issue
Jianxia
@NickPotter @LakesGISMaps, Thank you for letting us know. It appears this may be a regression from the ArcGIS Online update last night. Could you please share a reproducible sample with us, or contact Esri Support to submit the issue?
NickPotter
As you can see from the attached screenshot when trying to update it wants a response in every box with a Red warning triangle, this didn't happen before the update.
sosero
by Esri Contributor
@NickPotter @LakesGISMaps ,
This issue was logged as a bug Internally. If you have a case with Techincal support, you should have already been attached to the bug. If not, I request opening a case with our team, and we will attach your case to the bug.
