problem installing Experience Builder Developer Edition 1.0
3833
04-05-2020 06:23 PM
JohnCartwright3
Hello All,
I'm having problem getting Experience Builder 1.0 installed.  Installed the node modules (using node v10.18.1). When I run "npm start" and go to https://localhost:3001, I get this from Chrome:
"localhost normally uses encryption to protect your information. When Google Chrome tried to connect to localhost this time, the website sent back unusual and incorrect credentials. This may happen when an attacker is trying to pretend to be localhost, or a Wi-Fi sign-in screen has interrupted the connection. Your information is still secure because Google Chrome stopped the connection before any data was exchanged.
You cannot visit localhost right now because the website sent scrambled credentials that Google Chrome cannot process. Network errors and attacks are usually temporary, so this page will probably work later."
I understand it's using a self-signed cert but this is new to me.  I was able to run the beta version w/o issues on this Mac (version 10.15.3).
Can anyone suggest a solution?
Thanks!
--john
DavidMartinez
Hi John,
Open chrome://flags/#allow-insecure-localhost in address bar and enable the setting, then restart Chrome. I tested this with one of my colleagues who have macOC Catalina installed and local host worked as expected. We will have to update the doc for users on Catalina. Let me know if this works for you.
Cheers,
David
DanPatterson_Retired
Just in case you haven't see the notes
ArcGIS Experience Builder install | ArcGIS Experience Builder
and requirements
Requirements | ArcGIS Experience Builder
None of the bugs seem relevant
https://support.esri.com/en/Search-Results#search?q=%22experience%20builder%22&content-type=Bugs
Most recent blog about the final release, in case you haven't seen it
ArcGIS Experience Builder Developer Edition Final Release
And last, perhapsJianxia Song‌ will have a shorter more concise answer
JohnCartwright3
Thanks Dan. I have been through these docs and re-installed a couple of
times with no success.
--john
DavidMartinez
Hi John,
Cheers,
David
JohnCartwright3
Thanks David, that worked perfectly!
--john
