Print Widget not showing legend using custom print service, has issues rendering layer effects
16708
31
07-03-2022 02:41 PM
andrewdc_tt
I love that the print tool is finally available in Experience Builder, but there are some issues when printing using custom templates. We are using a print service hosted on a server with ArcGIS 10.9.1 and published with ArcGIS Pro.
1 - The legend does not populate at all, even with the 'Show legend' option ticked.
When using the exact same print service and map using the WebAppBuilder print widget, the legend displays with no issues in the print (left is Experience Builder, right is WebAppBuilder).
2 - Layer effects created in the new Map Viewer (such as drop shadow) do not render properly.
I've found it introduces weird graphical glitches, and labels/symbology seem to be blurry/distorted. The black lines introduced below go away after the drop shadow effect was removed from the map. This problem doesn't seem to be limited to just custom templates however, the default print does this too.
The default print service won't cut it for us unfortunately because of the map template layouts we need. Are these bugs able to be fixed?
Service_SIG_CAPDFT
the legend is still not displayed for me.
I'm using a model published from arcgis pro 2.9 on an enterprise 10.9.1 server.
I'm calling the print service URL from an experience builder app on our argis online portal.
Thank you for your assistance.
Service_SIG_CAPDFT
I finnaly manged to understand that you need to check the option "Only show visible content" in arcgis pro before publishing the model.
