Print Widget not printing Polygon layers
267
3 weeks ago
Jillian_MAPSS
I have a web map with a polygon layer and the polygon layer is styled using a date field, from oldest (lighter red) to newest (darker red)
When using the Print widget, with default print utility and default settings, the polygons do not show on the print map and the styling is not kept in the ledged of the printed pdf.
When I select the polygons on the map first, before using the print widget, then the polygon shows on the printed pdf map but the styling is still incorrect.
I do not want to select the polygons first before printing as I do not want to filter the print widget to only show certain polygons but rather want to be able to see all polygons of the print area.
Jillian_MAPSS
With some deeper investigation, it appears that the following occurs:
When the map's extent change action is set to filter the data framework the polygons do not appear in the printed map.
When turning the extent change action off then the polygon's appear on the printed map.
BUT, the styling is still not correct...
How do I now get around this if I still want the extent change action to filter a table but also allow the Print widget to print correctly?
ShengdiZhang
Hi @Jillian_MAPSS ,
Which version of Experience Builder are you using? I can't reproduce this bug on the latest version of AGOL.
Shengdi
Jillian_MAPSS
Hello,
I am experiencing this issue in Enterprise v11.5
