PopupTemplate actions doesn't display icons
1286
10-26-2023 06:13 AM
ŁukaszWiszniewski
Hello,
I have created a custom PopupTemplate with actions. I add actions like :
import {ArrowLeft} from '../images/ArrowLeft.png';
import { arrowLeft16 } from "@esri/calcite-ui-icons
actions: [
                      icon: {arrowLeft16},
                      title: "Display item"
                      icon: {ArrowLeft},
                      title: "Add layer"
I have trouble with icon visibility. I tried to add local PNG file as an icon, and second way by esri icons library (npm install @esri/calcite-ui-icons --save). None of these approaches work. I also tried to use "image" instead of "icon" attribute's key, but it didn't help.
JeffreyThompson2
MVP Frequent Contributor
The sample widgets library has an example of how to pull in images from your files.
https://github.com/Esri/arcgis-experience-builder-sdk-resources/tree/master/widgets/use-assets
 <div className="m-2">
        <h4>1. Use <b><code>props.context.folderUrl</code></b> to load a large image from a URL. The image must be put in the <b>assets</b> folder because the <b>assets</b> folder will be copied to the <b>dist</b> directory on compile.</h4>
        <img style={{ width: '200px', height: '200px' }} src={`${props.context.folderUrl}dist/runtime/assets/large-image.jpg`}/>
      </div>
I have had good results with this first method.
GIS Developer
City of Arlington, Texas
