Popup scroll direction
1475
01-09-2024 09:01 AM
Jennifer_Parmeley
I am working in Experience Builder, Enterprise 11.1
I have a simple page with a section. The section has 5 views.
Each view has a sidebar widget with a map (and legend) and text that can be hidden.
In the first view the popup has a horizontal scroll bar.
In all other views the popup has a vertical scroll bar.
Is there a way to control which direction the scroll in the popup works?
The preference would be vertical scroll, but consistent would work too.
TonghuiMing
Hi @Jennifer_Parmeley
It looks to me like it has something to do with how you formated the pop-up information inside the Map Viewer. You can check if that's the same behavior in MV pop-ups.
Generally, we do not control that part of logic in Experience Builder.
TonghuiMing
Jennifer_Parmeley
Thank you! yes it was a map issue. I just wasn't seeing it until I put it in ExB. The map popup element inserted first determined the scroll direction. (or something like that)
I deleted the text and added it back in and the horizontal scroll was removed.
