Pop-up windows for layers added by the ExB Add Data widget
790
07-30-2025 11:32 AM
berniejconnors
@Jianxia
        Has the functionality for pop-up windows on added layers changed?  I was certain layers added with the Add Data widget would display a default pop-up window that included all attributes.  But I just added a couple layers to my ExB app and no pop-up windows are displayed when I click on a feature.  Did this functionality change with the June 2025 update to AGOL??
Bernie.
Ke_Xu
by Esri Regular Contributor
Hi @berniejconnors,
If you add map image layer by Add data widget, the popup doesn't display on the map. This is a known issue we have logged.
Ke
Ke_Xu
Hi @berniejconnors,
Ke
