Pass polygon centroid to direction widget from
1454
7
09-12-2024 09:39 AM
vijaybadugu
Whenever we select a record in a list widget, does it pass polygon centroid to direction widget source ? is there a way to do ?
DavidColey
MVP Frequent Contributor
I've yet to find a way to do that. It would be a nice enhancement if it could, as the webmap specification allows for it....
TianWen
Thanks for your post! We're currently considering an enhancement and will keep you updated on any progress.
vijaybadugu
Thanks for this enhancement.
vijaybadugu
Any update on this ?
vijaybadugu
I just customized out of box directions widget to allow points and modified the code accordingly
DavidColey
Hi @vijaybadugu  - What code did you modify? Are you working in the developer edition?  Why would the the 'out of box directions widget' not allow points?
vijaybadugu
Out of box widget only works for points. it does not work for polygons. I customized the code to allow polygon centroid points in data actions/
