Open popup on load
811
05-30-2022 09:31 PM
Stacy-Rendall
We are looking to integrate with an external system, such that the external system can open our web mapping application with one or more features from one of many layers selected and attributes be visible.
Using the data_id attribute in the URL query string features from a given layer can be selected, however there doesn't seem to be any good way to view the attributes. Is it possible for the Popup to simply show on load?
NOTE: to try and meet the requirement I've tested Feature Info widget, but it will display data for one layer only. I've played around with combining multiple Views (which can also be driven by query string) although that seems to result in a lot of "Cannot read properties of undefined (reading 'id')" errors and would probably make things tricky later...
Tags (3)
