Odd Experience Builder Behavior
501
04-06-2026 07:56 AM
FlightDeck
Hey All,
I am experiencing a bit of, what I think is, odd behavior from ExB. In our case ExB is hosted on ArcGIS Enterprise 11.3 incase that plays a role here. The first and least concerning issue I am seeing is that the fields are being displayed in a completely different order from what I have laid out and uploaded from ArcGIS Pro. While this is minor it represents a poor user experience for those that use this map. Since I will be re-creating the same map for multiple areas going through and manually reordering ~50 fields is a less than desirable option.
The second more impactful issue I am having is a field that does appear in my pop-ups when an object is selected is not appearing in my table widget or when I use the select tool and export to CSV. I have checked multiple places to make sure I didn't remove a permission or somehow remove the visibility of the field and thus far nothing stand out. The field happens to be BIGINT if that matters to how it might be displayed. If any one can offer any insight into why these issues are happening and how I might fix them, it would be greatly appreciated.
TIA.
David_McRitchie
Hey,
Is there any configuration within the Experience that might be reordering the order of your columns or are we using the Layer default?
If it is default then do we see the same behaviour in the Map Viewer or within a new Experience?
As for the Pop up issue, I'm not seeing any problems on my 11.3 test environment, do you see the same behaviour if you create a new Feature Layer that uses a Big Integer as a data type?
Hopefully those help narrow down the problem,
David
Esri UK -Technical Support Analyst
FlightDeck
@David_McRitchie - All of the layers are set to "default" and this behavior continues across multiple maps created from varying, but related data.
When I pull this layer up in Map Viewer and view the table, all Fields appear and are arranged in the expected order.
