Not able to load map in ExB
1488
07-28-2020 07:10 AM
KamranYusaf1
I have a Portal installation that is only working offline. I am trying to create an ExB application but i am not able to load a map that i have created and saved on my Portal. It seems like some proxy is trying to redirect to arcgisonline. I have attached screenshot of the request. Due to this the map is not loaded in my application.
Can someone point me to what causes this?
Any help would be appreciated.
Best Regards
Kamran
Wei_Ying
Hi Kamran,
Did you register ExB with this local portal as well?
Are you able to add Map widget and load default map?
