Near Me Widget - Summarise grouped attribute polygons within an area?
1239
10-16-2024 10:02 AM
OrlOsc
I am using the Near Me widget to summarise layers that fall within a defined area, such as distance and total intersection area.
What I am now trying to achieve is total intersected area for grouped values, where a dataset is complete over the surface of a country.
For example:
I have geological data coverage for a country as a polygon feature layer. It is split into bedrock types and I want to know the area of each bedrock type within the defined area only.
Such as:
Origin Count........................3
Igneous.............................3km2
Metamorphic....................2km2
Sedimentary......................5km2
Can this be achieved with the current tooling in Experience Builder on Enterprise?
Spatialelement
Hi @OrlOsc . Did you find an answer to this question?
EvaSalinas1
i'm also looking for a similar solution. i was relying on the Screening Widget tool in Web AppBuilder and I'm not able to replace that simple functionality using the Near Me Widget as ESRI has prescribed.
