My Location Widget issues on Mobile devices
1473
01-31-2025 08:41 AM
ErienneDavis
Hello - We have an experience we have built that needs to have the same/ similar capabilities to a much used WebApp Builder  application and are struggling with the My Location Widget.  This applications purpose is to be used on mobile devices to allow the public to see trail locations/ see their location while hiking.
In WebApp Builder, the my location function allowed for tracking and we had it set to follow location and it worked fairly well.
In Experience builder the my location built into the Map Widget does not track location, it will only pull current location and does not update if you move. So we added the My location widget and  enabled tracking but are having some issues. The map will not stay zoomed in to the location (set to be zoomed 1:2500) and keeps zooming out to the broad extent. Additionally the tracking will randomly turn off despite not being stopped by the user.
These issues have been appearing while testing on Android devices (unsure if they will also appear on Apple devices as we have not extensively tested those)
Any suggestions for these issues?
TianWen
Thanks for the feedback. The team is exploring an enhancement to further improve the overall experience. I'll keep you updated on the progress.
ConorFlynn
Any ideas why Locate in the map widget doesn't work continuously?
Ke_Xu
by Esri Regular Contributor
Hi @ErienneDavis@ErienneDavis,
This feature has been released on ArcGIS Online in February 2026 and will be available with ArcGIS Enterprise 12.1.
Steps:
1. In the Map widget settings, enable "Locate" tool.
2. Click Locate tool settings and enable watch location.
Please see the doc here https://docdev.arcgis.com/en/experience-builder/latest/configure-widgets/map-widget.htm.
Ke
