Mobile Pop Up Issue on device vs DE
1031
04-30-2025 07:44 AM
Brian_McLeer
MVP Regular Contributor
Experiencing an issue where pop ups in the the mobile viewer in Developer Edition show correctly by being over map elements such as scale bar, zoom in / out etc. as in the image below.
When viewing the application on an iPhone 14, map elements such as zoom in / out, scale bar, etc. are on top of the pop up. Any ideas or workarounds for this issue?
Brian_McLeer
Figured it out, for phone viewer I had to duplicate the widget, move the original to the pending list, and then enable the "Dock the pop-up" option.
Ke_Xu
by Esri Regular Contributor
Hi @Brian_McLeer
I will let you know as soon as it is fixed.
BUG-000175443 When opening ArcGIS Experience Builder in an iOS browser, the Map widget tools will appear in front of the pop-up.
Ke
Brian_McLeer
Thank you @Ke_Xu, I did not realize it was a BUG, I thought it was a setting update on my end. Thank you for logging it as a BUG.
Ke_Xu
Hi @Brian_McLeer,
This issue has been fixed in the June 2025 release and upcoming Developer Edition 1.18.
Ke
