Middle mouse click to pan the map widget
880
11-18-2024 10:08 AM
CameronLacelle
Is there a way to enable middle mouse click and drag to pan a map? This would be useful for doing a shift click multi-select where having the selection tool active disables the user's ability to pan the map.
Ke_Xu
by Esri Regular Contributor
Hi @CameronLacelle,
Thank you for pointing this out. The map does not currently support panning by dragging with the middle mouse button. We will look into this further to see if it can be enhanced.
Ke
CameronLacelle
@Ke_Xu thanks, it would definitely be practical to have this as a feature as most modern interactive mapping services have this.
