Maps SDK transitioning to Components in Jimu Development
1076
03-03-2025 08:56 AM
tssau
Regarding this post:  https://www.esri.com/arcgis-blog/products/js-api-arcgis/developers/javascript-maps-sdk-a-full-transi...
How will this affect custom ExB widget development? Is Esri updating the Jimu framework to accommodate these, or is it up to the user?
Allen_Zhang
The main change in Maps SDK is to separate the UI widgets from the core logic without UI.
The new widgets' underlying technology is https://developer.mozilla.org/en-US/docs/Web/API/Web_components
These changes do not affect the Jimu framework; instead, they require adaptive modifications by the ExB widgets that rely on Maps SDK widgets, such as Map, Measurement, Table, and Edit.
tssau
Let's take Sketch for example.
In a custom widget, how would you correctly swap to the web component?
 Widget
import Sketch from "@arcgis/core/widgets/Sketch";
const sketchWidget = new Sketch({
          view: jimuMapView.view,
          layer: graphicsLayer,
.... etc ...​
vs.
 Component
<arcgis-map basemap="topo-vector" center="139.5716,35.696" zoom="18">
   <arcgis-sketch position="top-right" creation-mode="update">
   </arcgis-sketch>
</arcgis-map>
Allen_Zhang
The component is more modern and intuitive for developers, so I think it's the right choice.
And we must consider that the widgets will be depracated in 2026Q1 and removed in 2027Q1.
