Map Zooms to 0,0
1657
11-15-2022 07:25 AM
ZachBodenner
MVP Regular Contributor
Hello,
I have a relatively simple Experience with a Map, List, and some text/picture widgets. The map has a single layer which is used in the list and text widgets. I have a Message Action that should trigger the map to zoom to the selected feature when it's clicked on in the list widget. However, the map zooms to 0,0. I have not been able to figure out why this is happening (I have a similarly simple Experience with the same list-to-map zoom function, which works just fine.)
Experience Builder Developer Edition v1.9, AGOL
Happy mapping,
- Zach
ZachBodenner
So I had previously read some other posts on the community that said projecting the data into web mercator solves this problem. I didn't really want to do that because we have all of our internal data in the same coordinate system. I tried just setting the coordinate system of the Pro map used to publish the data, and that actually did the trick. Hopefully that helps someone else!
Happy mapping,
- Zach
ZachBodenner
Happy mapping,
- Zach
