Map widget search bar not working in Experience Builder
247
07-06-2026 11:35 AM
LJackson29
@TonghuiMing We noticed today that the search bar in the map widget is no longer working in our EB apps in AGO most likely after the update. The search bar works in map viewer, but not when used in the EB Map Widget. See screen shots and more detailed notes below. We are using services published to Enterprise Portal (11.3) and added to AGO for use in maps/EB.
Search criteria set up in map
Map viewer - search works in map viewer
EB App - You are unable to type anything and there is no drop down
Search is turned on in the map widget
Leila
LJackson29
@Ke_Xu This appears to be fixed as of this morning. Thanks for looking into it.
Best,
Leila
Laura
by MVP Regular Contributor
Works for me just fine. Did you clear cache? Try in incognito mode? Different browsers? All computers are like this?
Ke_Xu
by Esri Regular Contributor
Hi @LJackson29,
I couldn't reproduce this issue. Could you contact the Support team to help reproduce your issue?
Ke
LJackson29
Best,
Leila
