Map does not return to initial extent
831
03-17-2025 12:59 PM
Josh-R
I have an Experience Builder app that switches between four different initial extents using buttons. The first time I click a button, the map loads at the correct extent. However, if I move the map, the next time I click the button, it retains the extent where I last left off instead of resetting to the specified initial extent. Is there a setting we can disable to prevent this behavior?
example
Thanks!
Ke_Xu
by Esri Regular Contributor
Hi @Josh-R,
There in no other setting for this. Clicking the Home tool or refreshing the page can return to the initial extent.
Ke
