Looking for examples of Experience Builder projects that filter & display one-to-many relationships
623
04-24-2026 12:21 PM
Michael_Rehberg
Hi there. Using the current Experience Builder, but have also been using Survey 123 and looking into Dashboards. For all of these I'm using a polygon feature class with several joined one-to-many attribute tables. Which accommodate attribute fields that can have 1 or more values.
The structure seems to work, and setting up the Relationship Classes and Join Views are fine. But where I fall short is - trying to filter on and display features and tables using these several one-to-many relationships per polygon.
Could someone possibly point me to a good example of, say, an Experience Builder project that allows filtering or query using one-to-many relationships? Maybe you know of a good example / best practice of how to display a feature class and its one-to-many attribute tables gracefully? I might be missing a the obvious solution. Thanks.
ShengdiZhang
Hi @Michael_Rehberg ,
Some message actions support the use of relationships, such as "Data filtering changes - Data - Filter data records", though there are some limitations on the number of trigger data records.
You can find all message actions that support relationship at https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/action-triggers.htm#GUID-2D036...
Please let me know if you have other questions.
Shengdi
