Link Survey123 map and Experience Builder map together?
2335
01-17-2023 08:15 PM
ElliottCarson
Is it possible to link the Survey123 Map extent and the Experience builder extent map together?
So as use pans and zooms the extents are the same?
Also is it possible to link a mouse click from the Experience Builder to the Survey123 map?
I've done this we the "Send data to this survey" function, however our survey requires the user to add a new feature when filling out the form.
All suggestion are welcome and thanks for your response.
Elliott
Richard_Purkis
Hi @ElliottCarson
Currently it is not possible to link actions such as panning / zooming for these two maps. I recommend you raise this as an idea.
Thanks
Richard_Purkis
Hi @ElliottCarson
Thanks
NourSalamJMT
@ElliottCarson was this submitted as an idea? I would love to upvote it!
ECarson
No, I never raised this as an idea.
JamesGraham_cyclomedia
Hi @NourSalamJMT  - just wanted to let you know that a very similar idea has been submitted.  It would be great to have the Survey123 map and ExB map connected.
Upvote/add kudos to the idea here:
Synchronizing Extents and Interaction Between Surv... - Esri Community
