Legend in Swipe Map does not update dynamically
771
07-14-2025 07:22 AM
melisahansen
Is there a way to get the legend in experience builder to update dynamically with a swipe map. We have two maps that we want to swipe between, but the only way to get the legend to update based on the current map is to click on the side that you want to see the legend for. Or is there a way to show both legends at the same time.
We have the same issue with pop ups. They do not dynamically update based on where you move the slider. This is not user friendly for viewers of the map. The old map viewer gave much more flexibility for this. A solution for this would be greatly appreciated.
TianWen
Unfortunately, this is currently a limitation—the legend and popups rely on the Map widget to determine the active map view. We understand this may impact certain workflows and will continue to evaluate options to improve flexibility in future releases..
melisahansen
@TianWen
This is very unfortunate, the old functionality was much more desirable and user friendly and there are no current options remotely comparable to get similar results. Are there plans to bring this functionality back, and if so, what is the timeline for that? Losing this functionality with no replacement option has been a big issue.
