Lable toggle glitch
1479
02-16-2025 12:15 AM
Hels77
Does anyone know how to stop this effect when turning lables on and off via the Layer widget? It only flashes like this for a second, but is very noticable.
Ke_Xu
by Esri Regular Contributor
Hi @Hels77
You need to address the issue of overlapping annotations in the map viewer first.
Ke
Hels77
Thanks Ke.
In my web map there is no issue, that I can see. The lables beneath are hidden untill zoomed in to allow more space. Could you give me any more info as to what to adjust?
TonghuiMing
Hi @Hels77, do you have an example we could look at further?
Hels77
Hi Tonghui,
Yes I do. What info would you like me to share? I create this layer from a CSV export in ArcGIS Pro and upload it/ overwrite it on AGOL.
The same thing happens when disabling the label option in the webmap and within EB.
TonghuiMing
The shared URL of the experience & the web map would be enough for us to take a look, if possible. You can DM me the info. Thanks.
