labeling issues!
755
07-31-2025 09:54 AM
ClintOffutt1
This is not necessarily an ExB issues, more of a AGOL web map issues, but.....
What is going on with the polygon labels?  Something has changed recently.  I have several polygon with the same shape, but different labels.  For years, if I tried to label multiple layers, only the top label would draw.  AGOL doesn't have different labeling positions within the polygon.
I just had a user tell me now they are all labeling right on top of each other!  Attention ESRI web map developers, what is going on here?  What has changed and how do we fix it??!!
Laura
by MVP Regular Contributor
I label multiple layers and they all draw based on the centroid of the polygon, which happens to be the same polygon as I have view layers for different labeling purposes. To fix this I used the offset parameters in the labeling properties. That way I have 1 label towards the top of the polygon and 1 towards the bottom. For the 3rd I edited the scale range so you see it when you don't see the other 2.
Laura
Ke_Xu
by Esri Regular Contributor
Hi @ClintOffutt1,
It is recommended to contact the Support team to open a ticket.
Ke
