June 2026 Update: Unable to stack points
929
12
06-26-2026 08:11 AM
ChristinaNeal
With the recent update, our team is now experiencing issues with stacking points within one of our layers. We receive an error that says: "Something went wrong. Edits could not be saved: Layer does not support z values while feature has z values." This was never an issue prior to the update. Do we have to modify how our layer is published now or is this an experience builder bug?
CraigGillgrass
This issue was addressed on July 3rd. If you still encounter this issue, please let us know.
MikeVolz
Are the points being stacked in Experience Builder or are the points being stacked in GIS desktop software (ArcGIS Pro) and then just viewed s stacked points in Experience Builder?
ChristinaNeal
They are being stacked in experience builder.
CraigGillgrass
@ChristinaNeal are you able to reproduce this in either Map Viewer or the Web Editor?
ChristinaNeal
I just tested it and received an error in both Map Viewer and Web Editor.
CraigGillgrass
thanks @ChristinaNeal I will take a look and reach out if I run into any issues with reproducing it.
Jianxia
@ChristinaNealThank you for letting us know. It appears this may be a regression from the ArcGIS Online update last night. Could you please share a reproducible sample with us, or contact Esri Support to submit the issue? As @CraigGillgrass mentioned , we aim to narrow down the source of the problem - whether it is specific to Experience Builder or related to an underlying component that could affect other ArcGIS apps as well.
CraigGillgrass
@ChristinaNeal can you contact me at [email protected] so we can work through this issue?
Ethan_Bassett
I am having a similar problem since the latest update. In Experience Builder I move points of one feature layer A to match the location of points in another feature layer B. Anytime I attempt to move A to match a point from B, I get the same error message: "Something went wrong. Edits could not be saved: Layer does not support z values while feature has z values." Feature layer A does not have z-values enabled, but B does. That being said, this was not a problem until the most recent update.
ChristinaNeal
I opened a ticket and met with Esri Support today. The bug # is BUG-000185874 and it is currently "In Review."
