Issue installing node.js modules for Experience Builder Developer edition
2777
6
03-27-2020 09:35 AM
BobCarberry1
In the process of trying to install the new Experience Builder Developer edition v1.0,  I have run into a snag.  I followed  these instructions: ArcGIS Experience Builder install | ArcGIS Experience Builder  up to step 8 for the Server install section.  When putting in the command npm ci to install the modules, an error is thrown:
I am running windows 10 and have Node.js 10.19 64 bit installed.  Any ides?  Thanks!
JamesGough
Try running the command from a command prompt with administrative privileges (in start right click Command Prompt and click "Run as Administrator")
BobCarberry1
James,  thanks for your quick response!  I tried your suggestion but unfortunately it didn't work...same error message.  Any other suggestions?Sent from my T-Mobile 4G LTE Device
DavidMartinez
Hi Bob, what rights do you have to your machine? Can you install software etc.?
David
BobCarberry1
Yes...I have admin rights to load software.Sent from my T-Mobile 4G LTE Device
BobCarberry1
I figured it out.... I was trying to install on a network drive.  I moved it to the c:\ drive and everything install with no problem.
DavidMartinez
This is good news.
David
